west central ohio | Good friend of mine put a hypermax turbo on his ford f-450 with the 7.3 IDI. it was a lower mileage motor, but when he put that turbo on, it had more power, but suddenly created a oil blow by issue. He had to alter the crankcase vent on the valve cover to keep from blowing oil everywhere. Now, i do not know if this was a problem with just the engine he had, or if it was across the board. He ran that setup several years until it eventually blew a injector. Again, probably not any fault of adding the turbo. | |
