SA | I have a New Holland T7 which already has OEM guidance, and I am planning to set it up with an ISOBUS planting system. I have noted in previous posts that software update and configuration is not that easy on these displays, and also, manuals and documentation are not easy to find, even not available for latest software versions. In addition, I have seen that not all NH / CNH dealers are experienced with ISOBUS setups.
So, I´d be glad if any of the experienced users could hepl clarify:
- What are the recommended software packages that the dealer must install in order for the Virtual Terminal andTask Controller to run properly?
- For Intelliview IV, is the latest version of TC software the recommended one? Which version number should that be?
- As Intelliview is known for not having the best processing capacity, is it recommended not to load software that won´t be used?
t(a lot)ia | |
