Posted 4/13/2009 19:06 (#679128 - in reply to #678626) Subject: RE: Cruizer and reciever location on an 8640 Deere 4WD?
Boone, Iowa
Any 4WD tractor that I have seen has the antenna at the front or ahead of the cab. The reason is that they are trying to get close to the centerline of the front axle. This helps take out some of the movement you get from the articulation. Helps stabilize the line you are trying to follow.
