Outback guidance files to Case Pro 700 Trimble
mojave
Posted 10/21/2020 21:04 (#8558251)
Subject: Outback guidance files to Case Pro 700 Trimble
NE SD
Anyone know how to get Outback guidance files into a Case Pro 700 monitor with Trimble guidance. Both RTK. We were successful at getting them transferred through SMS into the 700 and the A-B lines have the same heading and work but are not where they should be in the field. The bigger problem is that the headland curved guidance lines while appearing to look as they should in the 700 screen make the tractor jump back and forth like its trying to choose between two different lines a foot or so apart making it impossible to let the tractor autosteer like that. Seems like there may be a simple solution to this because they appear correct on the screen and sort of work but not good enough to use for making strips that we can plant on next spring.
