Posted 4/12/2009 22:51 (#678352 - in reply to #677590) Subject: RE: How to Hitch up Relays
SW Ohio
One reason you may consider putting the relays on the airseeder is if you have several lights you want to control individually. Then you might run ( for example ) one large gauge hot wire and a cable of several small gauge wires rather than several ( not as large as the single large ) large gauge wires. One large gauge ground wire is needed in either case.
