IL | Noble1 - 4/11/2009 23:09
Not sure what you mean by TG, Getting late I guess.
We have the Antennae at the front of the Cab.
WHen the EZ motor was pushing against the wheel before it would really turn hard.
After I cleaned the bushings up and put the graphite to it it still turns harder when the motor is against it but is definately an improvment.
was able to raise the angle per turn up to around 18 or so from 14 or 15.
Haven't had it in a worked field yet but in the pasture it drives good and strait.
If it is turning the wheel to hard move the ez-steer motor away from the wheel a little bit. |
