roaming | I haven't tried it, but I'm 99% sure you can set the same seed for both planter sides.
I don't know if the file format changed or not. It could be that the file format was developed to support this feature but was just never used before. Or it could be that the format had to be changed to accomodate this feature.
I assume you're licensing the Voyager2 component from Ag Leader; if so, you can probably check with them to see if any changes were required. | |
