SW Illinois | only alarm code that came up was PTP 3 2000.09. "canbus error" ground speed limited. ground speed is only limited when header height is engaged. It is limited to .6 MPH in low, 1.1 mph in high. With header raised it will move full speed, even with separator running. Any ideas or easy things to check.
Dealer service hasn't returned call yet, but have looked at it before and said "no active codes so everything must be OK" | |
