Posted 9/27/2020 23:14 (#8518799 - in reply to #8518655) Subject: RE: running a 2600 in jd9770
Osakis, MN
You should be able to set a fixed moisture setting and set the moisture sensor to sample 0 times/ minute. This will allow at least and average moisture reading allowing the yield monitor to keep reading yield. It won't be as accurate obviously but it at least gives descent data.
