Converting a 500 Rowtrac from Nav to steercommand. I have everything hooked up, the incommand sees the steering controller, but I cant get it to calibrate. Its like it isn't communicating with tractor. The deadband test doesn't do anything.
I can go into the components section, select the steering valve, select hard left and nothing happens.
Are their some settings I need to change in the pro700?
