SC MN | What does the bottom of your well end in, rock or sand. My well ends in rock so when sediment shows up, its usually because of a hole in the casing. In our area if it ends in sand, they usually put a screen on the bottom to help prevent sand from being sucked up with the water. Your well seems new enough that I doubt the casing could be bad already. Have you talked to your well man about the issue? Might have to get some centrifugal filters and
purge them everyday. | |
