Central Nebraska | Dad built a bracket to mount the nav controller mount on. It tied on the 2 bolt hole in the bottom of seat, behind the seat. If you take the kick plate off the front of the seat you can see those holes. Had to cut up the rubber cubby hole back there for it all to fit. Nav sits so the connections are facing up.
You will probably have to build your own castle nut to hold on the autosense. Trimble guy tracked 1 down for me and it was $50+. So I went to dealer and got 2 nuts, screwed them on the tie rod end so the castles were facing each other and welded it together. | |
