Southern MN | I agree with Otis. Run in auto and let it do its thing for a pass. Verify incoming and outgoing moisture, calibrate it and then let it be. Check on periodically to make sure ranges are still in line throughout the season.
When I started with ours, I soon realized I was calibrating way too often and confusing it. Now, I set, calibrate, and then periodically verify exit moisture.
Edited by TheDude 9/7/2020 20:48
