Posted 4/7/2009 22:15 (#672907 - in reply to #672678) Subject: RE: Insight, Implement Switch, & Multiple Modules
Hillsboro, AL
Are you sure your implement switch "Y" is on the correct wire? One wire sends voltage out to the switch and the other brings it back from the switch. You want the "Y" on the branch coming back. It is the black wire in the Implement switch weather pack (B terminal if I remember right).
