| Is this the BT Device label "AMAN". Not supported on Android, not saying somebody couldn't make it work. I couldn't get it to work on Android.
Under RTK setup have you set up as an external CMR or RTCM radio this needs to match your mountpoint your using. And your Baudrate at 38,400.
With having to run NEMA out to your 2020 that will have to come out of Nav. port.
I have also had to repin the harness with AMAN BT Devices.
Login information for RTK network is case sensitive it is easy to fat finger something. Is account active?
Some other things to check. | |
