East Central, Nebraska | yes this should not be a problem. take nmea out of the steer command and send it into the pro monitor. in the steer command menu you can turn this on and off. another way would be to use and unused port if you have a dual port serial cable and take it out of there. that would be setup on the tab of that particular port under the receiver menu. taking gps out of the steer command is better because that data will be terrain compensated.
where you put the data back into the pro700 would depend on what harnessing and tractor your using and how it is setup. others will likely be able to help better on that topic. | |
