Macoupin County IL | We got everthing adjusted & went out to a grassy spot today & made the clutchs work looks like it is going to work good
Had a little trouble getting the products to show up on the layer page but figured out that you had to pick them in the run page first
then it was a option to pick them in a layer.
Had trouble getting my wing wheels to lower in the unfold mode had to go to fold & lower them in the raise wing wheel mode could not make it work in unfold got frustrated & put it away in the shed before I shut it off I tried it one more time & it worked in the unfold mode ????????????
it would try to set the frame while in lower wing wheels mode
After rereading torn post from last night I am not sure if I first picked the product first in run or work will have to try again tommorow
1250 ver 21
Edited by swcil 4/7/2009 18:27
