Posted 4/6/2009 21:55 (#671598 - in reply to #671525) Subject: RE: Another Problem with Rate Controller and Kinze??
I'm assuming this is JD. Did you change from the brown original greenstar system to a 2600 for this season? For some reason, the same switch in the same position reads opposite on the two systems. I think you can use the same switch and just change the recording source on the machine tab on the equipment softkey to record when open.
