roaming | You do not need to go to Toolbox > Product every time. You go to Toolbox > Product to complete all of your product setups. Once you have all your products set up, you go to Work Condition > Layer to assign a product to a layer for mapping. The Product(s) assigned on the Layer screen are the ones that will be applied/mapped.
To recap:
To set up your master list of Products (liquid, granular, seed, etc.): Toolbox > Product
To choose which Product(s) you are currently applying/mapping: Work Condition > Layer
You change your Products in the Work Condition screen, not the Run screen, because the Products can be tied to the Work Condition. So if you have a particular set of varieties/liquids/etc, you can set up a Work Condition with that set of Products, and whenever you need to apply that set of Products, you just select that Work Condition.
Edited by torn 4/6/2009 21:59
