Northern New York | I m in the northeast and am wondering where I would go to get my ez boom serviced. I am having 2 problems first I am trying to use it with a CaseIH version of an EZ guide plus and it doesn t auto rate control manual works fine. Second I m using it as a rate controler with a Raven Flow meter and a Raven rate control valve this part worked fine during the beginning of the season at the end of the season the flow control valve started cycling open and closed all the time. Had to unplug it to get it to stop or it would drain the batery when you turned it off. TIA
Scot | |
