Southeast NC | I had the same problem when i hooked the rate controller tied to the tru-count clutches up to the 2600 ....called stellarsupport and they said it was a known issue and what you have to do is basically what you've already done....create another "planting" operation and set up the dual varieties in that operation.....then they said you needed to change the first "planting" operation with the single variety setup to a bogus crop, like oats or something, ....i think this was primarily for documentation purposes, so when you unload your data, you know which planting operation really needs to be unloaded......otherwise it thinks it's planted double the amount of corn that it actually has if you unload both operations and they are both named "corn"......once you've unloaded the right "planting" operation, i guess it would be the normal procedure for creating the variety locator.<br />
Edited by sdwalton 4/6/2009 19:06
