Grand Forks County ND | If you unlock a Trimble FMD for xp, you are unlocking the 252 receiver, correct.
If I wanted to move xp equipment in the fall would I have to move both the 252 and the display? Can I leave the nav controller?
Assuming I can, if I remove the 252 and FMD can I hook up a 500 to the same nav controller? If so what cable do I need? Do you need different software on the Nav controller? Do I need to recalibrate the nav controller with the 500 display?
So many questions, thanks for the help.
