| There is a very easy way to calibrate the SPS center calibration value. Simply engage the SmarTrax and let the system do its thing. While engaged, on the SmarTrax controller, arrow to the right to "Steering Sensor Configuration" menu. From there, arrow down to "SPS Cal Center" screen. Press and hold right arrowuntil it advances to the "SPS Cal Right" screen. Press and hold the up and down arrows to bring you back to home screen screen. The system should move the vehicle over to the line. Good luck! | |
