Boone, Iowa | I have a 32 ft Krause 1955 rockflex disc that I bought a few years ago. I had problems with a spot plugging up on the right rear gang. It is always between the same two blades and cannot figure out why. We installed new blades and bearings last year and replaced or adjusted the scrapers, as needed. I went out the other day to find out it still plugs up. We tried looping a chain around the frame to keep the dirt from building up, but did not help. Granted, the dirt was a little wet, but does not plug up anywhere else on the disc. Thanks for any help. | |
