Nebo, Kentucky | I used one a few years back, worksaver I think. It had manual leveling which was kind of a pita, but MUCH better than digging holes. And the posts were really set once in the ground! We put a 6 inch post in the wrong spot and thought we would just pull it up with the loader on the tractor, WRONG. Ended up sawing it off level with the ground. I think you can rent them, if that would work for you.
We never broke a post, but sometimes we messed up the top of the posts pretty bad. I think if I were going to do it again, I would try to make some kinda jig cap for the posts. | |
