Posted 4/5/2009 19:35 (#669987 - in reply to #669660) Subject: Re: 20.8x42 Triples Tire Pressure?
If you don't add extra weight, you can drop the pressure down to 6-7 psi. The best thing to do would be to weigh the front and rear axle separately, then add cast weight to correctly ballast the tractor, then inflate the tires to the pressure recommended by Firestone for the weight of each axle.
