Sunnyvale, CA | the radio for the Ag252 depends upon the type of radio that is used by the base station to send the corrections. If the base and rover talk the same format on the mutually agreed to frequency, then good results can usually be obtained. If the base and rover radios are not compatible, then no data will be received. the first question you need to ask the base station owner is what kind of radios are used at the base station, then the radio for the Ag252 becomes a lot easier to specify. At theAg252 the radio for the corrections sends the data to the Ag252 B connector serial port. | |
