 WC Franklin Co., In. | That monitor should read 13 rows (I have no experience with them on how to set that up, but should be pretty straight forward). Probably take a different wiring harness so all the rows go to one mating connector for the 20/20. Ag Express can make a custom harness economically. You will need a properly calibrated speed input to the 20/20 to have population readings. You should at minimum have high rate sensors in the planter for beans, or ideally the wave vision sensors, but they will set you back around $140/row vs $80/row for the high rate sensors.
Edited by buenymayor 7/31/2020 04:57
