Search Forums | Classifieds (198) | Skins | Language
case 372 on case ih 4420 sprayer
notinteresting
Posted 7/24/2020 09:27 (#8393012)
Subject: case 372 on case ih 4420 sprayer
I have a case 372 running RTK on a 2008 case ih 4420 sprayer. I am using the FM 1000+app on a trimble 2050. The steering works great, but the product rate does not work right. Product rate holds below desired rate and is very erratic. Speed readout is very stable. We have narrowed it down to the 372 because if I use an ag 25 receiver the rate holds perfectly. I am wanting to use the 372 for RTK corrections because it is unlocked already.
Does anybody know what settings have to be changed in the 372 to make rate correct?
Also, on the same machine. I am wanting to use the master product switch on the joystick to control product. There is a setting in the implement settings in the fm 1000 app for external master product switch. Does anybody know the pinout to use for this switch? I see there is also an implement lift switch available. Maybe one of these settings will work for me.
TIA. I know there are some great minds on these forums, and I have learned a lot from you guys.
