Edgeley, ND | A couple days ago a problem arose with the #2 hydraulic SCV on my 7930. The hydraulics suddenly worked in one direction and not the other (IE the implement would lift and not lower). If you switched the hoses the implement would lower but not raise. Another this is it would tend to leak down as well. After looking online I suspected I may have a faulty SCV barrel so changed both barrels out on number 2 but nothing changed. Anybodody out there have the same issue?
Thank you in advance for any help you could suggest | |
