Can you configure the AF base to output CMR messages? Do you know what message the AF Base is outputting? I used an AF base several years ago, but that base had no User Interface. You pluged it up and it ran. You could make no changes to it. I don't know what the capabilites are of the current AF base. But, if it will output a message that Trimble can read it will work with the correct radios.
