Posted 7/11/2020 21:21 (#8368089 - in reply to #8366991) Subject: RE: Wilger Nozzle Bodies and Caps ?
SW Ohio
I would guess the oring that goes into the top of the end body. Little o ring around that metal injector. Mine drip if that is messed up or the o ring that seals the top where solenoid screws in. Or the plunger is bad. Look at the rubber where it seats against the metal orfice. It will just dribble and leak if it has uneven wear or a hole in it.
