Thumb of Michigan | I wouldn't even consider that burnt. Just let's you know that you've been through the field. I've ran plenty of mixes with 2 gallon of fertilizer in the mix, liquid K heats it up a bit.
Any reason you didn't run more than a quart of glufosinate?
I know you were chasing the marestail escapes and most of the cost is already there at a quart, I usually run 36 oz minimum. | |
