Posted 6/30/2020 16:53 (#8345801 - in reply to #8345348) Subject: RE: Hx15 slip clutch
Dix (Boyd), IL
Hard to tell from this angle, but looks like you have those 6 bolts too tight. The flat thin piece (Bellville spring) behind the lock nuts should not be tight against the last plate. Your manual will tell you how much gap to leave. Your clutch should have slipped before the yoke broke.
