Callao, Missouri | At least the noise in your cab is probably loud enough to help drown out the beeping noise from that planter monitor. I've got the same monitor on my planter that is for sale, and I have a shop towel folded and duct taped over the bottom beeper to keep my sanity as I turn the machine around.
How are you running the harnesses out of the cab? My machine has a spot on the left step, but my harnesses aren't long enough to use it. So I cut a 2" hole behind the seat.
