WC MN | Run Acutrak with TruTracker, biggest issue is making sure wires are good since you are now twice as complicated, make sure roll cal is good on tractor before using TruTracker. Use ours for strip till and planting in addition to sidedress. Can also nudge implement separate from tractor. Your orientation same as we run. I think our Sunco hitches are getting close to a decade old, potentiometer failed once and valve body can airlock once in a while, very sturdy. Also make sure you have plenty of sway in 3pt arms,absolutely will not work if no side travel in arms, at least in our hills. | |
