Posted 6/17/2020 15:24 (#8320443 - in reply to #8320101) Subject: RE: Trimble globes
NW Ohio
Not sure if there is an actual difference other than the body. The AG 25 replaced it. The Z plus had issues of no support other than the brass threads. On tile plows, this would cause the body to crack around it and make it go bad. guys used to cut a piece of 6" PVC to place under it to support the outer edges along with the bolt.
