Azul, Argentina | Check your boundaries, sometimes, data isn't correctly assigned to each field. Also, double check if correct product is selected. Sometimes the operator forgot to change the product and you will have 2 layers: soybeans 2020 corn 2020. You can edit it and unify the product.
If no boundary was present at upload time, set it, and then go to archive and reprocess all the pertinent files.
