Iowa - Floyd County | Run a T8.410 and really like it. No issues with it since we've owned it and does everything we ask it to. Moving from an MX Magnum took a bit of getting used to with the separate throttle and shift levers but not a big deal. Neighbor had a T8.360 burn up, said that stalks built up around the exhaust and started burning. Apparently it was an issue on the tier 4A tractors but the neighbor is the only one around here that has had a problem. They did redesign the exhaust area on the tier 4B tractors, which is what our 410 is. | |
