Classifieds (187)
Case IH Trimble swath copying to run offset rows
Precision Talk
Fingers77
5/31/2020 21:09 (#8291782 - in reply to #8291767)
RE: Case IH Trimble swath copying to run offset rows
If you want the pin, you either need to export the entire field or from the swaths tab, export the lines individually.
However, you will still need to export the coverage map
(event
) as well if you export the lines individually
vrvfarms
: 5/31/2020 21:02
Fingers77
: 5/31/2020 21:09
