Posted 5/23/2020 11:25 (#8275187 - in reply to #8274964) Subject: RE: White 2-105 steering problems
Your pump may be bad. Try turning the compensator valve in 1/8 of a turn. That valve is on the end of the main pump next to the battery box. If that does not work, get someone to check the hydraulic pressure. Pressure should be about 2150psi.
