Search Forums | Classifieds (51) | Skins | Language
Viper pro and accuboom
Amc4life
Posted 5/19/2020 10:55 (#8267019 - in reply to #8267007)
Subject: RE: Viper pro and accuboom
Butterfield, MN
Ok, so on that system, it should be run with the boom switches turned on when running. If you have AccuBoom enabled, the sections appear to be turning off on the screen, but they aren't turning off the boom section valves. If you turn section switches off while in a job with AccuBoom enabled, will it turn the sections off both on the screen and the sections? I question if the AccuBoom node is even on the system. Here's a link to the install manual:
https://portal.ravenprecision.com/ProductDocumentation/Download?atta...
As I understand it, it's almost like the AccuBoom node is on the CAN bus, but the place where it tees into the boom section wires isn't plugged in, as shown on page 5.
