Posted 5/20/2020 12:01 (#8269410 - in reply to #8258641) Subject: RE: Ezboom problem
Could it be that turning the pump would give voltage to pin 10 on plug 1 (Auxiliary Master Input) and would then over drive the master switch position?
Do you turn the pump on electrically?
If this is the case then just cut the wire going to that pin....
