Posted 5/16/2020 00:11 (#8259508 - in reply to #8257887) Subject: RE: Hyd Pump or Parts for 1980 IH S series straight truck
Southern Nevada desert
Look here to get an idea: https://www.google.com/search?q=truck+pto+hydraulic+pump&sxsrf=ALeKk...
A local truck shop should be able to help you.
Give us an idea what you have now, Direct mount or remote with a small driveshaft? 2 bolt or 4 bolt if direct mount?
The tag on the old pump should direct you towards the gallons per minute, rotation direction, and psi rating
