Creighton, NE | I'm doing an install on a 1770nt and it seems like the sprocket should be moved over more than the thickness of two washers but the chain is already very close to the heavy duty down pressure springs. The alignment is not perfect but it would be nice if it was over a little farther, maybe the planters with air bags have a little more clearance in that area.
The harness I got looks like it is designed for a straight 1770 and not a nt. From the center it has three leads that come off the main harness and then a long space and then five more down the line to the end. After investigating I found an extension cable that I believe would go on that #3 lead to extend it back to the middle and down the frame towards the front since that row unit is folded on this planter. I suppose making it more generic keeps the cost down.
It's supposed to be in the teens here the next couple mornings, I think there's a little time to get this job done yet. | |
