| To everyone that helped out on this, thanks. We've discovered some weird things that are going on and there will probably be a post in the precision ag board in a few days. For now though we've discovered that one of the 6V batteries has a cell that is bad only intermittently. We had the battery that we suspected totally disconnected from the electrical system of the tractor and put a load tester on it and it was fine. We decided we were going to replace it anyways and we moved the batter to a different position away from the tractor and tested it again out of curiosity literally 30 seconds later and it was running 4 volts without a load and essentially nothing under load.
That being said, we're pretty sure that's not all of the electrical problems with this tractor and as I mentioned, I'll probably be posting more questions in the precision forum later. Thanks again. | |
