Search Forums | Classifieds (3) | Skins | Language
pressure transducer cal
farmboy87
Posted 4/8/2020 19:04 (#8174455)
Subject: pressure transducer cal
IL
trying to get a pressure transducer to calibrate in a Ag Leader versa that I got from FDS. It is a John Blue SS2208 series. I had to adapt the end of the cable to fit the ag leader harness. I used a Deutsch 4 pin cable utilizing 3 pins same color coding each side. For one I can not find a MV/PSI number. Second, even if I enter the wrong value, should I still see a psi value on the run page? currently seeing nothing and I am using a set point of 0. Thanks for any help in advance both ag leader dealer and technician support not help
