Posted 4/8/2020 10:38 (#8173534 - in reply to #8173426) Subject: RE: Center Pivot formula for speed and application amount?
Midwest
There should be a chart inside the panel for rates. The simplest was is to set a hog pan out in the field and run the pivot then use a tape measure to see how much is in it.
