nw pa | CASE3594 - 4/7/2020 20:32
Are you using the flasher switch in the road light position or just in the flasher position? Can’t recall now whether midrange magnums use the same flasher switch as the bigger magnums but I think it’s a 3 position switch as well. One way is just flashers and the other is flashers/headlights. Center position is off.
Yes center position is off when rocking switch to left(headlights ). they don't come on. None of the other headlights.. Long as four ways are on. Just went out and checked,when rocker is pushed to headlights the four ways come on but no headlights.Four way side works
Edited by sri 4/7/2020 20:48
