Northeast Colorado | Trying to control a pwm hydraulic drive on a John blue piston pump. It will run and adjust speed in manual mode, but won’t turn on/off with the master switch. It will stop the motor when you turn the monitor off with the power switch. How do I get it to turn on/off with the master switch? Also how would I put a mercury switch in the system to turn on and off when the three point is lowered and raised? | |
